particle tracking
Old   April 12, 2006, 16:53
Default particle tracking
mike
I am trying to do particle tracking, and the .trk file is 0 kb.( no particle information is written). Do you have any idea why that might be happening?
Thanks, Mike
Old   April 13, 2006, 10:50
Default Re: particle tracking
James
How did you input particles(step or pulse) and how the particles was monitored(point or average)?
It would be easier to make comments if you provide more details about your modelling.
Regards!
James
Old   April 13, 2006, 12:41
mike
Hi James,
Thanks for your help. Is it important to monitor the particles? Can`t I just write the data to the .res file or .trk file without monitoring?
Below I added most of the .out file. I hope you can tell me my mistake.
Thanks again James,
Mike
LIBRARY:
MATERIAL: Tracer
Material Group = User
Option = Pure Substance
Thermodynamic State = Liquid
PROPERTIES:
Option = General Material
DYNAMIC VISCOSITY:
Dynamic Viscosity = 0.00089 [kg m^-1 s^-1]
Option = Value
END
EQUATION OF STATE:
Density = 997 [kg m^-3]
Molar Mass = 1.0 [kg kmol^-1]
Option = Value xxxxxxxxxxxxxx "I erased the water (bulk fluid) properties."
EXECUTION CONTROL:
PARALLEL HOST LIBRARY:
HOST DEFINITION: iherecfxmodeld
Remote Host Name = IHE-RECFXMODELD
Host Architecture String = intel_xeon64.sse2_winnt5.1
Installation Root = C:\Program Files\Ansys Inc\CFX\CFX-%v
END
END
PARTITIONER STEP CONTROL:
Multidomain Option = Independent Partitioning
Runtime Priority = Standard
MEMORY CONTROL:
Memory Allocation Factor = 1.2
END
PARTITIONING TYPE:
MeTiS Type = k-way
Option = MeTiS
Partition Size Rule = Automatic
Partition Weight Factors = 0.500, 0.500
END
END
RUN DEFINITION:
Definition File = C:/userMY/TestRun/TestsimulationP.def
Initial Values File = \
C:/userMY/TestRun/Testsimulation_003.dir/2322_full.bak
Interpolate Initial Values = Off
Run Mode = Full
END
SOLVER STEP CONTROL:
EXECUTABLE SELECTION:
Double Precision = Off
END
MEMORY CONTROL:
Memory Allocation Factor = 1.0
END
PARALLEL ENVIRONMENT:
Number of Processes = 2
Start Method = MPICH Local Parallel for Windows
Parallel Host List = iherecfxmodeld*2
END
END END FLOW:
DOMAIN: Default Domain
Coord Frame = Coord 0
Domain Type = Fluid
Fluids List = Water
Location = Assembly
Particles List = Tracer xxxxxxxxx "Inlet and Outlet"
BOUNDARY: walls
Boundary Type = WALL
Location = walls
BOUNDARY CONDITIONS:
WALL INFLUENCE ON FLOW:
Option = No Slip
END
END
FLUID: Tracer
VELOCITY:
Option = Restitution Coefficient
Parallel Coefficient of Restitution = 1.0
Perpendicular Coefficient of Restitution = 0.8
END
END
END
END
BOUNDARY: freesurface
Location = freesurface
Option = Free Slip
END
END
FLUID: Tracer
VELOCITY:
END
END
END
END
BOUNDARY: sen
Location = Default 2D Region
Option = No Slip
END
END
FLUID: Tracer
VELOCITY:
END
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Option = Non Buoyant
END
DOMAIN MOTION:
Option = Stationary
END
REFERENCE PRESSURE:
Reference Pressure = 1 [atm]
END
END
FLUID: Tracer
FLUID MODELS:
MORPHOLOGY:
Option = Dispersed Particle Transport Fluid
PARTICLE DIAMETER DISTRIBUTION:
Maximum Diameter = 0.0005 [m]
Mean Diameter = 0.00025 [m]
Minimum Diameter = 0.00005 [m]
Option = Normal in Diameter by Mass
Standard Deviation in Diameter = 7e-05 [m]
END
END
END
END
FLUID: Water
FLUID MODELS:
MORPHOLOGY:
Option = Continuous Fluid
END
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Option = None
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = SST
END
TURBULENT WALL FUNCTIONS:
Option = Automatic
END
END
FLUID PAIR: Water | Tracer
Particle Coupling = One-way Coupling
MOMENTUM TRANSFER:
DRAG FORCE:
Option = Schiller Naumann
END
PRESSURE GRADIENT FORCE:
Option = None
END
TURBULENT DISPERSION FORCE:
Option = None
END
VIRTUAL MASS FORCE:
Option = None
END
END
END
INITIALISATION:
Option = Automatic
INITIAL CONDITIONS:
Velocity Type = Cartesian
CARTESIAN VELOCITY COMPONENTS:
Option = Automatic
END
EPSILON:
Option = Automatic
END
K:
Option = Automatic
END
STATIC PRESSURE:
Option = Automatic
END
END
END
PARTICLE INJECTION REGION: Particle Injection Region 1
FLUID: Tracer
INJECTION CONDITIONS:
INJECTION METHOD:
Cone Angle = 25.0 [deg]
Injection Centre = 0 [m], 0.65 [m], -0.8 [m]
Injection Velocity Magnitude = 0.001 [m s^-1]
Option = Cone
INJECTION DIRECTION:
Injection Direction X Component = 0
Injection Direction Y Component = 0
Injection Direction Z Component = 1
Option = Cartesian Components
END
NUMBER OF POSITIONS:
Number per Unit Time and Mass Flow Rate = 0.0001 [kg^-1]
Option = Proportional to Mass Flow Rate
END
END
PARTICLE MASS FLOW RATE:
Mass Flow Rate = 0.01 [kg s^-1]
END
END
END
END
END
OUTPUT CONTROL:
MONITOR OBJECTS:
Monitor Coefficient Loop Convergence = False
MONITOR BALANCES:
Option = Full
END
MONITOR FORCES:
Option = Full
END
MONITOR PARTICLES:
Option = Full
END
MONITOR RESIDUALS:
Option = Full
END
MONITOR TOTALS:
Option = Full
END
END
PARTICLE TRACK FILE:
Keep Track File = On
Option = All Track Positions
Track File Format = formatted
Track Positions = Control Volume Faces
END
RESULTS:
File Compression Level = Default
Option = Standard
END
TRANSIENT RESULTS: Transient Results 1
Option = Standard
Time Interval = 0.2 [s]
END
END
SIMULATION TYPE:
Option = Transient
INITIAL TIME:
Option = Automatic with Value
Time = 0 [s]
END
TIME DURATION:
Option = Total Time
Total Time = 40 [s]
END
TIME STEPS:
Option = Timesteps
Timesteps = 0.2 [s]
END
END
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
SOLVER CONTROL:
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Maximum Number of Coefficient Loops = 4
Timescale Control = Coefficient Loops
END
CONVERGENCE CRITERIA:
Conservation Target = 0.01
Residual Target = 1e-04
Residual Type = RMS
END
PARTICLE CONTROL:
PARTICLE INTEGRATION:
Option = Forward Euler
END
END
TRANSIENT SCHEME:
Option = Second Order Backward Euler
END
END END COMMAND FILE:
Version = 10.0
Results Version = 10.0 END
Old   April 17, 2006, 00:05
James
Did you see the particle number changes during the run in solver? You may need to check your tracer input condition if the particle number is 0
And the purpose of setting monitoring points is to get tracer curves.
Regards!
James
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump scatman CFX 7 January 8, 2018 00:59
massless particle tracking problem Renold FLUENT 0 January 26, 2011 14:23
Particle Tracking for ion Jun CFX 2 August 31, 2010 08:19
Number density tracking rather than particle tracking Rebecca Main CFD Forum 2 April 23, 2009 12:52
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
