PVM Error
Old   April 24, 2006, 06:47
Default PVM Error
saturn
Dear all: I used CFX Parallel PVM function, but it showd the following error. How do I fix this problem?
Error message:
+--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | Unable to start the PVM daemon on host xpc7. This may indicate | | that the PVM daemon is already running on that host, or that it | | left files in /tmp on that host because it did not exit cleanly | | last time it was run. | +--------------------------------------------------------------------+
Old   April 24, 2006, 16:04
Default Re: PVM Error
Meri
You must have ended your simulation without the demon turned off. Go to /tmp and delete all the file(s) pv*, that should do it.
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
