Turbulent Schmidt number
Like Tree1Likes
  • 1 Post By Mike
Old   April 26, 2006, 11:38
Default Turbulent Schmidt number
Terry
Hi, Guys.
Can someone advise how to change Turbulent Schmidt number for transport equations in CFX10? Thanks!
Terry
Old   April 26, 2006, 11:44
Default Re: Turbulent Schmidt number
Mike
Add the following CCL to your HEAT TRANSFER MODEL object. The transport equations will pick up this value as well as the heat transfer equation. This won't work if Option = Isothermal.
HEAT TRANSFER MODEL: Option = Thermal Energy TURBULENT FLUX CLOSURE:
Option = Eddy Diffusivity
Turbulent Schmidt Number = 0.9 END END
Mike
rockzh likes this.
Old   April 26, 2006, 11:48
opaque
Dear Terry,
Since you ask for Turbulent Schmidt Number, I guess you want to modify the turbulent model equations such k, epsilon or omega.. Those are in the GUI under TURBULENCE MODEL/ADVANCED CONTROL/(K/EPSILON/RS) COEFFICIENTS..
If you want to change the Energy equation you must add the CCL manually, and it is called Turbulent Prandtl Number instead.. For mass fraction, the value for energy is used for consistency.
Good luck Opaque.
Old   April 26, 2006, 12:03
Terry
Thanks all.
I want to change the Turbulent Schmidt Number of additinal varible transport equations(to ignore the effects of turbulent diffusion), so Opaque's method should be good for me.
Regards!
Terry
Low Reynolds number k-E Turbulent Model Sohail FLUENT 19 July 16, 2020 14:08
Turbulent Schmidt Number John FLUENT 8 June 1, 2015 05:04
Problem with decomposePar tool vinz OpenFOAM Pre-Processing 18 January 26, 2011 02:17
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Question on Schmidt number ap Main CFD Forum 0 March 26, 2008 18:58
