Integration with Fieldview
Old   May 3, 2006, 04:21
Default Integration with Fieldview
Dominik
i need help regarding the capabilities of fieldview. I've got a 3d (X,Y,Z) concentration field and want to integrate only in Z-direction, or better said i want to average in Z-direction. The result should be a new X,Y contour plot. In the function pop-up you can't integrate and in the integration-controls-panel you obtain only the result of the integration of the current surface. Has anybody experience in this problem and is able to help me??
thanks
Dominik
Old   May 3, 2006, 10:15
Default Re: Integration with Fieldview
Atit
I am not sure if I understand you exactly. In my case, I write expression to integrate some properties, such as, temperature, pressure, or density over the planes perpendicular to the flow direction. In the expression, I use 'FOR' to change the position of those planes. Is this the thing you want?
Old   May 4, 2006, 11:10
Dominik
uhh,
what actually is 'FOR'? Fortran? I want to average a 3d concentration field in one direction. The result is 2d concentration field.
cheers
Dominik
Old   May 5, 2006, 02:14
Dominik
uhh,
cheers
Dominik
Old   May 7, 2006, 13:28
Atit
I enter the following code in 'command editor' of CFX-Post. I hope you can adapt it to what you want.
!open (OUTFILE_bfAD, ">ResultFiles/RotTube_velvel_Buoyant_rotat_bf.dat"); !for ($i=0; $i<=10; $i++) { #calculate a new value of y !$Y = 4.1 + $i * 4.58; # change the plane location PLANE: Plane 1 Option = ZX Plane Y = $Y [m] END !$Press = massFlowAve("Pressure", "Plane 1"); !$ptot = massFlowAve("Total Pressure", "Plane 1"); !$Temp = massFlowAve("Temperature", "Plane 1"); !$Vel = massFlowAve("Velocity", "Plane 1"); !$u_vel = massFlowAve("Velocity u", "Plane 1"); !$v_vel = massFlowAve("Velocity v", "Plane 1"); !$w_vel = massFlowAve("Velocity w", "Plane 1"); !$Den = massFlowAve("Density", "Plane 1"); !$enthalS = massFlowInt("enthalpy", "Plane 1"); !$entroS = massFlowInt("entropy", "Plane 1"); !$mvel = massFlowInt("Velocity", "Plane 1"); !$AreaP = area("Plane 1"); !$vel_theta = areaAve("Velocity u*Velocity u +Velocity w*Velocity w", "Plane 1"); !$mdot = massFlow("Plane 1"); !print OUTFILE_bfAD "$Y $Temp $Press $Den $Vel $u_vel $v_vel $w_vel $vel_theta $AreaP $mdot $enthalS $ptot $entroS $mvel\n"; !} !close (OUTFILE_bfAD);
About the integration along a line in CFX-post Zhihua Xie CFX 3 March 15, 2007 05:49
Integration with FIELDVIEW Dominik FLUENT 1 May 3, 2006 15:05
For Fluent and FieldView users Germain Lannegrand FLUENT 0 March 27, 2001 07:28
Fieldview Data Format?? Choong K. Yoo FieldView 0 August 23, 1999 19:59
Any numerical triple integration program is available in Fortran? Radhakrishnan Main CFD Forum 3 March 4, 1999 01:03
