using two fluids in simulation
Old   May 11, 2006, 08:14
Default using two fluids in simulation
ousegui
Posted - May 10 2006 : 12:29:00 --------------------------------------------------------------------------------
Hi I try tu model heat transfert beteen two fluid sepated by solid. But i can't selected it. CFX allows just 1 fluid for both I verify in licence ans i see we have multiflow options Can any body help me Thanks
Old   May 15, 2006, 09:13
Default Re: using two fluids in simulation
Kiddo
Hello, Just set up a system environment variable: CFX5_NO_CONSTANT_PHYSICS
and its value is T
Old   May 15, 2006, 09:20
ousegui
I'll try thanks
Old   May 15, 2006, 12:04
ousegui
Can somebody show me ho to up a system environment variable: CFX5_NO_CONSTANT_PHYSICS Thanks
Old   May 15, 2006, 21:53
Kiddo
1. If you're using Linux, edit /etc/profile and add the following line before <font color=blue>export</font> command <font color=red> CFX5_NO_CONSTANT_PHYSICS=T </font> and then export CFX5_NO_CONSTANT_PHYSICS 2. If you're using windows, just control-panel>system> and look for <font color=blue>environment</font> tab I'm sure you'll find it soon.
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 08:18
velocity profile export from a simulation onto another sudhirlv STAR-CCM+ 1 September 12, 2010 18:57
Simulation of mixing of two compressible fluids shinde.gopal OpenFOAM 1 September 7, 2010 09:37
multiple fluids depending on time seojaho CFX 6 April 13, 2010 15:37
Simulation of mixing of two compressible fluids shinde.gopal Main CFD Forum 0 December 10, 2009 04:08
