probe
Old   May 22, 2006, 06:03
Default probe
hydrogen
Hi!
I would like to know why it's not possible to use:
Entrada = probe(Mixture.H2 Ideal Gas.Mass Fraction)@Outlet
I've got this error:
ERROR #001100279 has occurred in subroutine ErrAction.
An error: Invalid locale in call back function probe on locale Outlet
Besides, I have an inlet which depends on this variable (Entrada) like that:
H2On = Sensor Function(Entrada,Limit,aitern) InletH2 --> Velocity Y = H2On*10 [m s^-1] Please, can anyone help me?
Old   May 22, 2006, 11:50
Default Re: probe
opaque
Dear hydrogen,
Probe is a callback function that can only be used on point locators..
You can refer to a monitor point defined by Cartesian Coordinates, Source Point, or a Radiometer..
Good luck,
Opaque
Old   May 22, 2006, 11:59
Default Re: probe
hydrogen=yolanda :-D
Yes, opaque. Both of us know that but it didn't work. This is the message I got:
The function 'probe' referenced in parameter 'V' in object '/FLOW/DOMAIN:Room/BOUNDARY:InletH2/BOUNDARY CONDITIONS/MASS AND MOMENTUM' has an invalid argument, 'Mixture.H2 Ideal Gas.Mass Fraction'. The prefixed variable is not valid in the context of the locator 'Detector'.
And Detector was a monitor point
Entrada=probe(Mixture.H2 Ideal Gas.Mass Fraction)@Detector
You told me that it could be because the pre-processor was "over-restrictive". What does that mean exactly? Thank you again!
Using Probe for part of a patch ndr OpenFOAM Running, Solving & CFD 7 April 4, 2019 06:26
functionObject Probe: it's possible to stop and restart? ivan_cozza OpenFOAM Post-Processing 0 September 28, 2010 04:42
create a probe with fluent Aenseeiht FLUENT 3 April 29, 2010 03:27
save data output at specific point using probe foam_noob OpenFOAM 0 March 11, 2010 02:13
Using probe lengthening time of run saf5029 OpenFOAM Running, Solving & CFD 4 July 30, 2008 10:05
