About fluid surface
Old   June 6, 2006, 08:23
Default About fluid surface
jasonchang
Hi,all
I am use cfx to simulate water filling into a vessel . It's a transient model.
How can I get the surface of water in the filling?I want show it in the animation. Any suggestion will be appreciated. Jason.
Old   June 6, 2006, 10:08
Default Re: About fluid surface
Robin
Create an isosurface of volume fraction 0.5 or plot volume fraction on a surface.
To close the walls, follow these steps:
1. Create a contour plot of volume fraction between 0 and 1 with three contour levels. Hide the contour.
2. Create a user surface using the "From Contour" method. Pick the contour plot you created in step 1 and set the contour level to 2 (or 3 depending on whether you picked air or water fraction).
Optionally, if you want combined control of the coloring, create a Surface Group and include your User Surface and Isosurface. Colour to taste and add transparency to wow your friends!
Regards, Robin
Old   June 7, 2006, 09:48
Jasonchang
Hi Robin,
Thank you for your help.I'll try it .
By the way ,I have another question: The tank filling model,with air in it ,but the pressure in it is very low,about 1000Pa. The inlet only allow water flow into the vessel .Shoule I use two phase model,set the inlet like this,water Volume Fraction 1,air Volume Fraction 0;homogeneou model;set the air Dispersed phase? Regards,Jason
Old   June 7, 2006, 21:32
Robin
Homogenous with free surface should be fine with water as the continuous phase (this doesn't matter so much when free surface option is selected). Volume fraction of 1 for water and 0 for air will introduce only water at the inlet. If you specify a mass flow rate or velocity at your inlet, you will run into problems without an outlet when the tank finishes filling.
Make sure the air phase is compressible.
-Robin
Old   June 7, 2006, 22:30
jasonchang
Hi,Robin
As the air is very few and compressive,I needn't set an outlet of the vessel.Indeed the inlet is at the bottom and there's no outlet.
I set the isosurface ,contour,user surface and user surface just as you said,but still have some question.
where should the contour be located?
I set the user surface and surface group and nothing appeared.
I am a beginner .Too many things haven't been got. Thank you sincerely. Regards,
Jason
Old   June 8, 2006, 08:45
Robin
Hi Jason,
You need to walk before you run. Have you been through the tutorials or taken training?
For the tips I gave, locate the contour plot on the outer boundaries. You can select multiple regions by clicking the [...] button beside the location selector and control-clicking on the desired locations.
This is a transient analysis. Are you writing TRN files at each iteration (or at least periodically)? What variables did you include in the trn files?
Regards, Robin
Old   June 9, 2006, 03:37
jasonchang
Hi,Robin:
I have been run the simulation,but I think there are still some mistakes I set. e.g,the pressure in the domain is 1000Pa,almost in vacuum.Perhaps I can't use the 'air at 25C' because the density and some other phsical properties is changed.Maybe I should add a new material by myslef.
I wrote TRN files at each iteration ,but not include variables in the trn files.Maybe it is just the reason I failed.
By the way,How to set the air phase compressible? Thank you for having given me so many advices. Regards,Jason
Old   June 9, 2006, 09:17
Robin
I don't mean to be rude Jason, but you should really think a little more before you begin. STP means Standard Temperature and Pressure... are you running at Standard Temperature and Pressure.... No! Don't get me started on writing a TRN file and not including variables!
Read some documentation, run a few tutuorials, then come back and ask questions.
If you are a student, pray that your prof is not reading this forum.
Regards, Robin
Old   June 9, 2006, 20:53
jasonchang
Thank you all the same. I try it by myself. Regurds,Jason
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 18:48
Calculating forces on a non-closed surface ScottN FLUENT 0 March 1, 2011 17:18
Free surface VOF (fluid render effect) franco STAR-CD 1 July 20, 2009 05:42
evaporation from a fluid surface sobhan nabavi FLUENT 1 July 31, 2006 13:59
Modeling of free surface in CFD ? Kim TaeMin Main CFD Forum 18 July 16, 2001 11:38
