Negative volume in ICEM CFD
Old   June 29, 2006, 05:41
Default Negative volume in ICEM CFD
hagupta
I am trying to hex-mesh my geometry in ICEM-CFD. I am getting some negative volume elements as can be seen in the link. The elements shown in the link are the only negative volume elements. http://ez-files.net/download2.php?a=...9bb952c19dfa0f
The geometry consists of a cylinder having three baloon shaped surfaces on the curved surface of the cylinder as seen. The screenshot in the link shows the region of the cylinder where the ballon shaped surfaces lie.
The negative volumes come up the moment I collapse certain blocks to get the blocks as seen.
What could be the cause of the same?
Any help or queries are appreciated.
Old   June 29, 2006, 05:52
Default Re: Negative volume in ICEM CFD
Joe
Your link is buggered usw www.imageshack.us
Old   June 29, 2006, 06:05
hagupta
This link should work http://img48.imageshack.us/img48/9466/screenshot4fn.png
Thanks Joe
Old   June 29, 2006, 08:38
myron
Go to Blocking > Check/Fix Blocks. Run 'Fix Inverted Blocks' then run 'Check/Fix'. See if that helps.
Old   June 30, 2006, 06:20
hagupta
Thanks, it removed the negative elements.
How to fix negative volume elements in icem cfd? shirish CFX 5 June 5, 2018 01:59
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
[ICEM] Problem with volume mesh in ICEM CFD kolapoasafa ANSYS Meshing & Geometry 2 September 16, 2011 03:54
Negative Volumes in Wigley Hull ICEM CFD Carlos Andrés CFX 2 March 1, 2010 02:55
ICEM CFD Modules Boris FLUENT 1 March 12, 2004 14:37
