dyn. viscosity as a function of particle Temp. |
July 6, 2006, 10:48 |
Hi all,
I would like to create a dyn. viscosity of my liquid particles as a function of the particle temperature. Has anybody experience with this? I am using CFX 10.0 and a lagrangian particle model. Is it possible to solve this problem without using fortran subroutines? If yes how can I find out the variablename of the particle Temperature? Cheers, Felix |
July 7, 2006, 00:14 |
Re: dyn. viscosity as a function of particle Temp.
hi just explain ur problem clearly what ur simulating exactly
July 7, 2006, 03:19 |
I am simulating the motion of liquid and inert particles with a diameter of 0.1 micron in a gas flow. You can define a value for the dyn. viscosity in the "material properties" -> "Transport properties" settings. And I want to create a function for this dyn. viscosity which depends on the particle temperature. The background of my question is that I would like to associate the perpendicular/parallel coefficient with that dyn. viscosity to obtain a behaviour for the stickiness of the particles. Do you need more information?
Felix |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 06:27 |
Casson Viscosity model as one user define function | Zahra Rahmdel | FLUENT | 0 | November 6, 2004 05:53 |
Why tne viscosity in LBM have tunning function? | TSYen | Main CFD Forum | 0 | October 25, 2004 20:54 |
Density of liquid Sapphire as function of temp. | J.W.Ryu | FLUENT | 0 | September 8, 2003 02:24 |
