what exactly is the Courant Number ???
Old   July 26, 2006, 13:09
Default what exactly is the Courant Number ???
CFX Novice
Please, could you explain what is the Courant Number? I tried to find it in CFX-doc, but there is mentioned only with timestem adaptation. But I'd lik to understand it more. So is it has any math. definion? Thanks in advance
What is my problem - I hav a hard problem with transident run (pointed into time-average solutin, I don't care about the unsteady effect) but my courant number varies from 150 to 600 within a few timesteps. Could be it problem with convergence? Thanks
I'm using SST, unstructured mesh, Re 7.5e7 and TS is 0.5 s
Old   July 26, 2006, 13:40
Default Re: what exactly is the Courant Number ???
mike
Hi Novice,
I recommend you to write "courant number" in search, and you will find necessary information about it. If you are using cfx, and you are interested in time-averaged solution, you dont need to worry about it.
Mike
Courant number fireman FLUENT 7 September 11, 2021 11:33
IcoFoam unstability, courant number gets large! vivien OpenFOAM 11 March 9, 2017 03:45
LES near wall model & courant number kasim CFX 5 March 16, 2008 18:23
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Courant number calculation - unsteady flow Kuba FLUENT 0 November 8, 2005 22:44
