ANSYS problem in solving fluid fluid interaction
Old   July 24, 2006, 09:03
Default ANSYS problem in solving fluid fluid interaction
Fayyaz
please help me , can i use simple ansys 10.0 Flotran for simulating free stream flow over a plate with a angled hole in the plate in which same fluid is flowing with different properties.. for film cooling of the plate...i have only option to work in flotran cfd.... could i try the two different flows as two materials or if i use single type of material then it is posing problems saying soluition is diverging. i have tried all the methods...pls help me if some one has worked on such a problem
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
Computational time sunnysun OpenFOAM Running, Solving & CFD 5 March 16, 2009 03:32
Negative value of k causing simulation to stop velan OpenFOAM Running, Solving & CFD 1 October 17, 2008 05:36
