Excel
Old   August 4, 2006, 13:09
Default Excel
yolan
Hi all!
I would like to know how can i get my results, insert them in an Excel file and compare different cases and get some graphs. Is it possible to open the .res files in any way? I've tried making a table but i haven't succeeded. Could you help me please? Thank you very much.
Old   August 7, 2006, 01:35
Default Re: Excel
Patrick
You can export all relevant data. But you will get problems if your Excel file has more than 64'000 lines (that's often the case if you export some data for every finite volume). Then you better proceed with a better tool like Matlab.
Old   August 7, 2006, 02:55
Default Re: Excel
yolan
Thank you for your help Patrick but, could you explain me how I must do that exactly? I've tried and I don't succeed. Thank you again.
Old   August 7, 2006, 05:45
Default Re: Excel
Patrick
CFX Post: File -> Expor: Select the values and save it as .csv file. You can open that with Excel.
Old   August 7, 2006, 10:55
Default Re: Excel
yolan
Thank you very much! That has worked quite well but I would like to get a table with two columns: the first is the time (or the time step) and the other one the variable I'm interested in. I have got those data just for each time but not for all the time steps at a time. Is that possible? Thank you!!
Old   August 8, 2006, 22:39
Default Re: Excel
HekLeR
Easiest route would have been to create a monitor point in CFX Pre and then export from the solver manager.
Now you will have to write a script for CFX Post instead.
Old   August 9, 2006, 02:49
Default Re: Excel
yolan
Yes! I have a monitor point!!! But is it possible to export to Excel from the solver manager? is the procedure the same? Tnank you!
Old   August 9, 2006, 10:46
Default Re: Excel
johnny
Right click on the monitor point graph and click export plot data.
How to plot a contour from an excel file in Tecplot? gholamghar Tecplot 9 February 11, 2021 13:43
Reading MS Excel Data in STAR-CCM+ using a Macro BrenS STAR-CCM+ 1 May 20, 2010 14:38
Radiation and VBA using Excel kapo84 OpenFOAM 2 January 21, 2010 06:46
Advanced post-processing (to Excel) Felix CFX 4 May 2, 2008 13:30
how to export data to Excel bikash FLUENT 3 September 14, 2004 20:58
