August 15, 2006, 08:35 |
How to get the surface normal vector
Hi, I want to use the surface normal vector at curvelinear surface. That is, the normal direction is a variable over the whole surface. Many users in this forum mentioned the CEL variable e.g. "Normal X". But it seems it is not a recognised variable in CFX Pre. Can somebody tell me why? Or give me some hints how to obtain the surface normal. Thanks a lot!
August 16, 2006, 03:02 |
Re: How to get the surface normal vector
have u try projection vectors on cfx post? do u want to put surface normal vector as BC in PRE? or do u just want to obtain values on post?
August 16, 2006, 03:40 |
Thanks Alex. I want to set the BC in Pre using the surface normal vector. I read some old posts in this forum, one mentioned that the "Normal X" variable e.g., is only valid in Post. I tried to obtain the surface normal vector with User Fortran subroutine USER_GET_MESHDATA, but I failed with setting a correct LOCALE. The comment on this subroutine is not sufficient. I tried to read the LOCALE with the subroutine USER_CALC_INFO. However, the returned LOCALE by this routine can't satisfy the argument of USER_GET_MESHDATA with I try to use it on a wall boundary. Do you have any idea on that?
February 1, 2018, 05:45 |
Dimitrios S. P.
Rep Power: 8 |
look at -> Normal vector variable of curved surface
How to get normal vector to the face? | Viatcheslav Kulikov | FLUENT | 1 | August 31, 2017 03:03 |
Unit normal vector of nearest wall | l_r_mcglashan | OpenFOAM Programming & Development | 3 | May 13, 2014 17:06 |
calculating Normal vector in level set method | amir2920 | Main CFD Forum | 1 | July 21, 2009 07:25 |
how to resolve the a vector normal to a cell surfa | ztdep | Main CFD Forum | 1 | August 6, 2008 14:42 |
