Need help fixing/defining Reynolds no. using CFX
Old   August 19, 2006, 15:57
Default Need help fixing/defining Reynolds no. using CFX
Ravi
I have been trying to run a simple case of a flow over a cylinder. Though, I could get going with everything, I have not been able to fix the Reynolds number (Re=U*L/nu) (of my choice) for which I need to analyze the flow. A little investigation revealed that the solver was taking the Global length (L) as (domain size)^(1/3) where domain size=Lx*Ly*Lz, the product of domain length in all the three directions, though I was able to fix U=1.0 and nu=required value for air at standard conditions, I was not able to fix, L (global length). Physically, L is the length scale and for flow over a cylinder it is typically the diameter of the cylinder (say L=1, since my cylinder was of that diameter). But, instead it takes a value as explained above. Can anybody help me to fix this problem or tell me how to go about this.
thanks, ravi.
Old   August 21, 2006, 07:38
Default Re: Need help fixing/defining Reynolds no. using C
Manu
Hi ravi, I did the same thing to fix the reynolds number in Backward facing Step and i found the results with good agreement.You should make sure that the Re is set ; e.g in my case Re = Density*Umax*InletHeight/Viscosity i fixed the Re by varying the viscosity as it has very little influence.And all the other things are fixed(Constant). Solver computes it on the basis of Global Length. Hope this will work.
Manu
Old   August 21, 2006, 09:16
Robin
Hi Ravi,
The Reynolds number calculated by the solver has no influence on your solution. It is simply an approximate Reynolds number produced as a reference. Don't modify your domain size to set this Reynolds number to anything. Rather, you should calculate your own Reynolds number based on the velocity, length scales and material properties that are relevant to your analysis.
Regards, Robin
Old   August 21, 2006, 23:45
Ravi
Hi Robin/Manu,
Thanks for the responses. This should help me to some extent.
regards, ravi.
Old   August 21, 2006, 23:48
Ravi
Hi Robin,
Do you have an email ID to which I can write?. Let me know.
thanks, ravi.
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
Calculate turbulent reynolds number in CFX Jervds CFX 2 May 11, 2009 09:18
Electronics Enclosure Analysis with CFX Simulation Engineer CFX 1 April 22, 2009 11:08
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
