How to model fluid flow through porous material |
September 14, 2006, 09:09 |
Hi, Friends I have to model a flow through a pipe having a porous material in it. Will any body please help me for the same? I am planning to use a source term in momentum equation to account for losses due to the porous material so what exactly should be the exact expression of the source term? Thanks Ram Dayal
September 14, 2006, 10:36 |
Re: How to model fluid flow through porous materia
You can define a Porous domain or a subdomain with Losses by setting the Permeability, the Resistance Loss Coefficient or the Momentum Source Coefficient. All these models are explained in the user-manual. F
September 14, 2006, 13:41 |
Thanks for reply Ok I will get permeability of the porus material but I have a doubt regarding this loss coefficient is it same as friction coefficient for the porus material. And what about actual velocity and superfecial velocity. It will be great if you could explain it little bit. Thanks once again. Ram Dayal
September 15, 2006, 06:05 |
I can't help you with the Full Porous Model, I've worked with Momentum Loss Model only, wich is quite different. The only thing I can tell you is that using the real velocity instead of superficial velocity implies that the permeability must be multiplied by the porosity, owing to the absence of flow volume reduction. Sorry. F
September 17, 2006, 01:28 |
can any one help me out in how to determine experimentally the porous media coefficient for the specific compnent instead of using the standard one prescribed in the CFX user manual
Two Domains (Porous Fluid) | Acto de Lima Cunha | CFX | 7 | April 17, 2013 21:29 |
[Other] Consistent mesh for fluid flow in fractured porous media | bemgeomechanic | OpenFOAM Meshing & Mesh Conversion | 0 | March 14, 2011 08:46 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
SLUG flow with Two fluid model and VOF | MIJAIL | Main CFD Forum | 2 | February 21, 2008 10:45 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
