How to perform a particle track in CFX(10) post?
Old   September 28, 2006, 08:34
Default How to perform a particle track in CFX(10) post?
Jordan
Hello, my question is if possible to perform a particle track on an already calculated flow field where no particle data has been set? Or is it always necessary to set particle information in CFXpre when working with CFX10? In the past we used TASCflow to perform particle tracks on e.g. with cfx4 calculated flow fields.
Best regards Jordan.
Old   September 28, 2006, 09:15
Default Re: How to perform a particle track in CFX(10) pos
Joe
Streamlines are available in CFX post.
Old   September 28, 2006, 12:03
Erik
Hi, as you said the particle information must be set in CFXpre. But it's a quick matter to do so by using your old result file as an initial solution to compute a new result file including particles.
cheers,
erik
Particle Track in CFX Jmac CFX 14 July 13, 2017 10:58
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Particle Track Domenico FLUENT 2 February 19, 2007 18:56
Particle track James Bewley CFX 0 April 28, 2006 06:04
Particle track files Sankalp CFX 1 August 25, 2004 23:25
