Remeshing in CFX10
Old   October 9, 2006, 09:00
Default Remeshing in CFX10
Stanislav Kraev
Is it possible to perform remeshing in CFX, i.e. change mesh topology (reduce or increase number of nodes and elements) in order to maintain mesh quality during calculation?
Thank you.
Old   October 9, 2006, 10:49
Default Re: Remeshing in CFX10
Joe
Only if you use the mesh adaptation feature (steady state only?). General mesh topology changes arnt allowed.
Old   October 9, 2006, 17:11
You can stop the simulation and restart with a new mesh and interpolate the results onto the new mesh. This allows changes of mesh topology in both steady and transient simulations.
Old   October 9, 2006, 18:43
Joe
If you are doing a transient run with moving meshes and you use this interpolation method, you can set the first few timesteps after the interpolation to be very small compared to the normal timestep size. This will help reestablish decent convergence levels.
You can automate this too using junction box routines i.e. use logic like:
After interpolation use 0.001*DT until convergence levels are below X threshold value whereafter use DT.
Old   October 10, 2006, 02:01
Stanislav Kraev
How can I simulate piston moving in CFX10. Major problem is that entire volume must be collapsed during piston moving. Is there some ideas how to avoid highly skewed elements?
Old   October 10, 2006, 17:15
Hi Stanislav,
Have a look at my PhD thesis. I used CFX4 to model an IC engine but the same methodology works for CFX5/CFX10 and is much easier to implement.
http://adt.lib.uts.edu.au/public/adt...018/index.html
Note that normal IC engines still have some clearance volume at TDC so the volume does not collapse to zero. You can use this to squish the mesh into the small space left and not do any mesh topology changes, at least for the piston motion.
Glen Horrocks
Old   October 10, 2006, 23:26
Stanislav Kraev
Glenn!
Thank you very much. Your thesis is very helpfull. I have only one question about it. Can I use this technique to simulate Fluid Structure Interaction (FSI) problem? I'm going to use CFX+Ansys. Do you know if it possible to control CFX by Fortran routines during FSI simulation?
Old   October 11, 2006, 17:36
I do not know the limitations of FSI. Talk to CFX support.
Remeshing with User Defined Options ChristianF CFX 2 September 24, 2014 09:19
Bugg in Remeshing in 3D - Any Fluent Wizards ?? Amr FLUENT 1 November 1, 2011 04:04
Importing CFX10 data into CFX 11 Stephen CFX 1 May 10, 2007 23:42
Importing CFX10 data into CFX 11 Stephen CFX 0 May 9, 2007 06:55
Dynamic Grid Remeshing causing Divergence? Andrew Wick FLUENT 0 January 23, 2006 18:39
