Icem - solver
Old   October 14, 2006, 08:37
Default Icem - solver
Jones
I have been trying to make a grid around an aerofoil using Icem. I have had a few problems when I try to run it through the Multiblock-info solver. I think it would be helpful if i knew how this solver generated the numbers. For now, it is jumping from -1 to -2 then back again...when it is meant to go smoothly till about -5. I also used bigeometric and other curves with points close to the aerofoil having a spacing of 10^-5. My tolerances for the curves were 10^-6 and for surfaces 10^-5. Also when I create a point using the curve intersection tool, the curve moves slightly. This is only visible if you have zoomed into the area quite alot. This is with setting the gap tolerance to 10^-6. SO after you try to create a surface with it, the curves dont join and it gives errors. I hope it is all understandable. Please let me know if it is not. Your help as soon as is possible would be really appreciated
Old   October 16, 2006, 07:57
Default Re: Icem - solver
myron
With such tight tolerances, you'll need to reduce the Triangle Tolerance value in the Global Mesh Parameters. Probably down to 10-5 or 10-6. This will make the geometry more 'true' to reality. Change the setting then save and reload the geometry. (You'll want to do any geometry manipulations with the smaller value.) This should help the meshing to be closer to the true geometry.
Old   October 17, 2006, 17:56
Jones
not sure what you mean by triangular tolerences. What does that mean? How does it affect everything? Where do you do that?
Old   October 19, 2006, 05:39
myron
Look in the Global Mesh Parameters settings for 'Triange Tolerance'. When a tetin file is loaded, it's actually facetized for memory purposes. When you lower the 'triangle tolerance' and re-load the tetin file, those facets are smaller so the geometry is closer to the true shape. This only has a large effect if you're using very tight mesh spacings - and/or you have large differences in geometry sizes.
PEM Fuel cell module meshes. ICEM vs workbench aarvay FLUENT 24 March 2, 2020 06:50
Creating New Solver: For particle-laden compressible jets sankarv OpenFOAM 0 April 4, 2010 18:06
Help for constructing an Unstructured Incompressible solver moomba Main CFD Forum 0 February 25, 2010 15:38
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 03:39
Symmetry plane error in solver Santiago Orrego. CFX 6 January 31, 2007 07:09
