Temperature regions
Old   December 1, 2006, 06:19
Default Temperature regions
Zoran Karabaic
I'm new to CFX, and need to obtain results in it, to make comparison with FLUENT.
Is there some way to set temperature regions on z-axis and patch them something like petching regions in fluent.
I need to obtain temperature diferents of sea layers - thermocline
thanke you in advance
Zoran
Old   December 1, 2006, 09:30
Default Re: Temperature regions
opaque
Dear Zoran,
The idea of patching as in FLUENT is not available in CFX..
However, CFX provides you with a different set of tools to do the same thing. Do you want to set a temperature profile/distribution within a 3d or 2d region?
In most cases the use of CEL expressions (mostly using the step function) is enough to set/initialize a variable on a region..
Please see for examples of using CEL.. They have been discussed in this Forum as well several times.
Opaque.
Old   December 1, 2006, 09:55
Zoran Karabaic
Thanke you for your post,
I wanna set temperature on 3d region. Ther would be 5-8 zones over the hight of some 50 units and domain is bay 50 metars deep in one end and 5 metars the other, 3 km long, 900 m wide at widest side and 30 m at other side.
I need to set initial domain with thermocline, becouse i'm modeling inlet of hot water on the side of the bay and on -45 m inlet of cold water. Need to see mixing of cold and hot water at inlet. I'm using bouyancy flow.
Zoran
Old   December 1, 2006, 13:08
opaque
Dear Zoran,
Write an CEL expression of the temperature variation as a function of height (perhaps Z direction) and then use it in the Initialisation panel for all domains (I imagine you associated a zone to a domain)..
Select Automatic with Value and use your expression on the RHS for Temperature..
Opaque
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
High temperature methane+air Peter FLUENT 5 January 26, 2009 18:04
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
