animation error
Old   October 23, 2006, 05:55
Default animation error
jon
I am trying to create an animation of a transient run and save it as an mpeg. I have done this many times before but now it is not working correctly.
The mpeg writes but obviously not properly as the mpeg is zero size and fails to play.
Any ideas? Thanks Jon
Old   October 23, 2006, 21:36
Default Re: animation error
TB
Assuming that you have enough space to store the mpeg file, have you checked if all the transient files are problem free? I suspect that one of your trn file is not written correctly. The quickest way is to check the size of your trn files.
Old   October 24, 2006, 06:21
Johnny
You can always write out the .jpgs as well and use a third party software to generate the mpeg.
Old   October 26, 2006, 10:57
TB
If you're using this approach, I'll suggest you to write the PNG file. Quality is much better this way.
Old   October 27, 2006, 08:00
jon
Any suggestions on software? Any that are free?!
Old   October 27, 2006, 09:19
Robin
Quicktime Pro isn't free, but it only costs $30 USD.
Old   October 30, 2006, 03:09
Michael B
Create higher quality videos from CFX
http://users.cybercity.dk/~ida3068/cfd/
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
