Hub Region Not Defined
Old   November 3, 2006, 06:27
Default Hub Region Not Defined
Flavio
Hi. In CFX-Post, under Turbo Menu, when starting Initialization i get the sequent warning message:
"Hub region is not defined for component 'xxxx' in domain 'xxx'. Cannot initialize turbo-processing module.
What could the reason be?
Thanks.
p.s. Is it better to impose a mass flow rate inlet boundary condition, associated with a average static pressure outlet condition, or the exact opposite?
Old   November 3, 2006, 06:36
Default Re: Hub Region Not Defined
sam
define ur turbo topology again with care
Old   November 3, 2006, 06:59
longbow
CFX-Post has a list of pre-defined names which Post recognizes as Hub. Your Hub region probably is not on that list. Therefore, when Post automatically initializes Turbo mode, it couldn't locate where Hub is. Try initializing Turbo mode mannually especially if you have both rotating and stationary domains. If your Hub region has a fixed name in your cases, you can add it to that pre-defined name list under "Edit/Option/Post/Turbo".
Old   November 6, 2006, 02:07
Ermanno
Hi, try initializing mannually ( as Longbow says).
As regards your second question I use (If I can)the following conditions:mass flow inlet/avarage static pressure outlet and it works, generally.
If you know the total inlet condition I think you can impose total condition inlet/mass flow outlet and it should work equally. (Manual says the first solution is more robust than second one)
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
