MFR or simply rotating wall???
Old   November 5, 2006, 13:45
Default MFR or simply rotating wall???
Italianboy
I want to simulate a blower-volute system. i know that i can do that using MFR and GGI between volute domain (stationary) and blower domain (rotating). But i am wondering if it is possible to create only one domain and set on cfx_pre the blower walls as rotating walls. What are the differences between the two methods???
Many thanks.
Old   November 5, 2006, 15:20
Default Re: MFR or simply rotating wall???
If the blower is rotating then the only way is using MFR. Just setting a wall velocity on the blades but keeping them stationary is not meaningful.
Old   November 5, 2006, 15:34
Italianboy
Thank you Glenn, but i don't understand why just setting a wall velocity on the blades keeping them stationary is not meaningful.
If you want to study the relative velocity, i agree with you; but if you just want to know for example the difference in pressure between the inlet and the outlet, setting only the wall velocity for blades should be enough.
I am trying to study MFR theory again but i am not able to find an algebrical explanation.
Many thanks again.
Bye
Old   November 5, 2006, 17:02
Camilo Costa
In CFX tutorial have one example whit MFR!!!
Old   November 6, 2006, 01:43
Italianboy
I know Camilo, the question was another.
Thanks
Old   November 6, 2006, 15:08
Keeping the mesh stationary but imposing a wall velocity is not meaningful. Try this mental experiment: Flow along a flat plate where the flat plate has a velocity perpendicular to the flow. Fluid which goes near the front of the plate is deflected upwards due to the wall velocity. This means no fluid can follow the surface of the plate as it has all been deflected upwards and continues to the exit with no influence of the wall. Some strange form of separation forms and I bet it won't converge.
As I said, this setup is not meaningful.
Old   November 6, 2006, 15:28
Bian
MFR is totally different from moving wall!!!
In rotating frame, the governing N-S equation for the flow has centrifugal force in it. Everyone forgot?
If your volute is round (or nearly), you might simplify the problem by simulating all in the rotating frame, and setting reverse direction rotating wall for the volute wall.
Bian
How to set rotating wall as boundary condition babu FLUENT 7 December 14, 2013 04:48
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Rotating wall: Pressure BC in OpenFoam using rhoCentralFoam solver vinaykr OpenFOAM 0 June 27, 2011 04:11
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
UDF for rotating wall Philippe FLUENT 0 January 30, 2006 11:03
