VOF
Old   October 31, 2006, 05:29
Default VOF
thandavanadhi
Does the latest version of CFX has Volume of fluid method for fluid surface tracking. Can anyone comment on this aspect
Thanks in advance
Old   October 31, 2006, 08:56
Default Re: VOF
Camilo Costa
This is a problem very important, because if you want tranking a interface bettween gas and liquid you need use this tecnic.
Old   October 31, 2006, 09:04
Default Re: VOF
Robin
Yes, you can track a free surface in any current version of CFX using homogenous multiphase with free surface turned on. See the tutorials for details.
-Robin
Old   October 31, 2006, 10:38
Default Re: VOF
Bak_Flow
Hi Thandavanadhi,
just a clarification. The term interface tracking usually refers to methods which actually move the mesh: "Boundary fitted grids are used, and they are re-adjusted each time the free surface is used" Ferziger and Peric 2ed, p. 356
VOF methods fall in the category of Interface CAPTURING methods.
CFX has the later...and it is very good. But not the former.
Tell us more about your application and you may get some specific tips.
Regards,
Bak_Flow
Old   November 10, 2006, 22:22
Default Re: VOF
thandavanadhi
Dear Bak_flow
I want to model dam break problem in CFX. I would like to use VOF in CFX. In the multiphase simulation this option is not coming.. What method CFX uses .?.
Thank you
Old   November 11, 2006, 12:20
Default Re: VOF
Robin
This is essentially what you get when you pick two fluids (i.e. Eularian-Eularian multiphase). There is a free surface tutorial (flow over a bump). Give it a try.
-Robin
VOF Inlet condition Rizwan FLUENT 15 July 5, 2018 16:33
Question:Considerations about the evaporation in VOF dokeun FLUENT 10 February 24, 2011 20:47
vof + hydrostatic pressure ariorus FLUENT 0 August 7, 2009 10:57
urgent query regarding vof model plz rply Garima Chaudhary FLUENT 0 July 13, 2007 02:20
Difficult BCs about Freesurface Simulation by VOF Yongguang Cheng FLUENT 0 September 19, 2003 07:39
