December 1, 2006, 06:19 |
Temperature regions
I'm new to CFX, and need to obtain results in it, to make comparison with FLUENT. Is there some way to set temperature regions on z-axis and patch them something like petching regions in fluent. I need to obtain temperature diferents of sea layers - thermocline thanke you in advance Zoran |
December 1, 2006, 09:30 |
Re: Temperature regions
Dear Zoran,
The idea of patching as in FLUENT is not available in CFX.. However, CFX provides you with a different set of tools to do the same thing. Do you want to set a temperature profile/distribution within a 3d or 2d region? In most cases the use of CEL expressions (mostly using the step function) is enough to set/initialize a variable on a region.. Please see for examples of using CEL.. They have been discussed in this Forum as well several times. Opaque. |
December 1, 2006, 09:55 |
Thanke you for your post,
I wanna set temperature on 3d region. Ther would be 5-8 zones over the hight of some 50 units and domain is bay 50 metars deep in one end and 5 metars the other, 3 km long, 900 m wide at widest side and 30 m at other side. I need to set initial domain with thermocline, becouse i'm modeling inlet of hot water on the side of the bay and on -45 m inlet of cold water. Need to see mixing of cold and hot water at inlet. I'm using bouyancy flow. Zoran |
December 1, 2006, 13:08 |
Dear Zoran,
Write an CEL expression of the temperature variation as a function of height (perhaps Z direction) and then use it in the Initialisation panel for all domains (I imagine you associated a zone to a domain).. Select Automatic with Value and use your expression on the RHS for Temperature.. Opaque |
Problem with zeroGradient wall BC for temperature - Total temperature loss | cboss | OpenFOAM | 12 | October 1, 2018 06:36 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
High temperature methane+air | Peter | FLUENT | 5 | January 26, 2009 18:04 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
