PROBLEM IN COMPLING IN UDF
Old   December 5, 2006, 12:51
Default PROBLEM IN COMPLING IN UDF
ammi
hi i am compiling a udf but facing the problem as below
when i am clicking in source file 1st time following error
Error: wta(1st) to string_length Error Object: ()
but sencond time it is taking file and same the case for header file as follow
Error: wta(1st) to string_length Error Object: () after that if i click build and load following error coming
The system cannot find the file specified. The system cannot find the file specified. The system cannot find the file specified. The system cannot find the file specified.
1 file(s) copied. The system cannot find the file specified.
1 file(s) copied.
1 file(s) copied. (system "move user_nt.udf delete2\ntx86\2d")0 (system "copy C:\Fluent.Inc\fluent6.1.22\src\makefile_nt.udf delete2\ntx86\2d\makefile") 1 file(s) copied. 0 (chdir "delete2")() (chdir "ntx86\2d")() 'nmake' is not recognized as an internal or external command, operable program or batch file. 'nmake' is not recognized as an internal or external command, operable program or batch file.
Done.
Opening library "delete2"... Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
i have installed VC++
HOW TO SOLVE IT
AMMI REDDY
Old   December 5, 2006, 23:43
Default Re: PROBLEM IN COMPLING IN UDF
Johnny
Try posting your question in the Fluent Forum
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
what's the problem with my udf zzyan FLUENT 0 November 4, 2010 03:56
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
UDF variables F1, y / problem with UDF Fabian FLUENT 6 June 2, 2003 10:22
