where to set CFX Transition Model?
Old   January 4, 2007, 10:11
Default where to set CFX Transition Model?
steven
hi,
According to CFX10 manual, looks like we can handel turbulence transition model. I want to set some parameters. I selected SST model, but there is not such as transition model tab at all. I tried to input from ccl, but it always says "it is not physically valid".
What should I do to get access to the transition model?
Thanks
Old   January 4, 2007, 12:27
Default Re: where to set CFX Transition Model?
Joe
Its right there ... just under the turb model selection drop down.
Old   January 4, 2007, 12:55
steven
i talked to an Ansys guy. Seems like we need to buy some sort of "advanced turbulence" license to activate this transition model.
Old   January 16, 2007, 18:19
Santiago Orrego.
Put this lines in the .pre file, because CFX 5.7.1 doesnt have a GUI option.
TURBULENCE MODEL:
Option = SST
TRANSITIONAL TURBULENCE:
Option = Gamma Theta Model
TRANSITION ONSET CORRELATION:
Option = Langtry Menter
END # ONSET CORRELATION
END # TRANSITIONAL TURBULENCE
END # TURBULENCE MODEL:
And read the manual to know about other models. Hope it helps.
Old   January 16, 2007, 18:21
Santiago Orrego.
I tried those lines, but in this time, I cant make converge the solution of a NACA airfoil. If anyody how make it converge, let me know please. Thanks santiago
Old   January 17, 2007, 10:38
opaque
Dear Steven and Santiago,
The transition model in ANSYS CFX has been evolving over the years (and releases)..
It became visible in ANSYS CFX 10.0 which is a good reason not to use a previous version (in 5.7.1 was beta feature).
Most important is that you require an additional license to use/access it. Please contact you CFX help desk or provider for information.
Opaque.
Old   January 17, 2007, 11:19
Santiago Orrego.
I made it converge, changing the Ratio to the mesh, to 1.02. Hope it helps santiago.
[ICEM] How to set bocos on 2D model for ANSYS CFX (tuts no help) RossFS ANSYS Meshing & Geometry 4 May 22, 2012 08:56
anybody using transition model in CFX littlelz CFX 7 May 11, 2011 06:48
Problem importing watertight model into CFX djk1301 ANSYS 3 February 1, 2011 22:04
modelling transition with v2f turbulence model pablo FLUENT 0 August 7, 2006 15:44
Help: 2D model in CFX 5.5 Dejun Jing CFX 1 July 24, 2002 00:25
