High Mach number solver error
Old   January 31, 2007, 07:47
Default High Mach number solver error
Luke
Hi, Im currently analysing the flow through a diffuser. I have developed a hex mesh for the same. The boundary conditions are 650 kg/s mass flow and 18000 Pa inlet total pressure. Initially i tried BC's of inlet mass flow and outlet static pressure but the solver exited with a "High Mach Number" at the inlet. I then tried a inlet total pressure and outlet static (giving a low value of static pressure to begin with) but the solver exits after around 200 iterations with the same error. I have also tried using a low physical timescale but with no avail. Couls someone please suggest a solution to this problem. Thanks in advance.
Luke
Old   January 31, 2007, 09:19
Default Re: High Mach number solver error
James Date
Luke
Start with simple convergent-divergent nozzle with a slower speed using total pressure inlet and static pressure outlet conditions. Try low order first then move to high order. Let it run for long enough. Ramp the speed up when it starts solving. Just a few things that helped me in the past.
James
Old   January 31, 2007, 09:54
sam
are you using symetry or periodic boundary conditions?
Old   January 31, 2007, 22:26
Eric
How about the outlet pressure? It is not the atmosphere.
How do you know the total pressure at inlet?
Eric
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
Error in CFX Solver Leuchte CFX 5 November 6, 2010 06:12
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
