Temperature gradient?
Old   February 8, 2007, 06:52
Default Temperature gradient?
Cote
Hi all,
I need to include in my simulation a momentum source which depends on the temperature gradient of the fluid. However:
1) Seems that the (letīs say) "Temperature.Gradient X(Y,Z)" is not part of the variables forseen in CFX 5. Am I right? At least, it is not displayed in the CFX-post as for density or velocity...
2) How should i proceed? Is there an easy way or example on how to calculate gradient and use it to define a user source?
Thanks is advance, Maria.
Old   February 8, 2007, 09:03
Default Re: Temperature gradient?
opaque
Dear Maria,
Please read the documentation about accessing the <Variable>.Gradient via User Fortran.. That is the way you access the gradients in ANSYS CFX 10.0..
ANSYS 11.0 is available if you contact you help representative.. Then, you can access the Temperature.Gradient X/Y/Z directly in CEL.
Opaque..
Temperature gradient in CFX Chander CFX 5 January 7, 2015 03:00
specified shear at wall - temperature gradient - UDF - access violation error senD Fluent UDF and Scheme Programming 9 September 18, 2014 07:29
Wall correction for the temperature gradient Hagen OpenFOAM 0 March 7, 2011 20:04
Temperature Gradient at Wall sven OpenFOAM 7 November 1, 2010 17:25
temperature normal gradient on a boundary Sandrine Main CFD Forum 2 June 10, 2009 16:34
