Help! Error of CFX10
Old   March 7, 2007, 00:59
Default Help! Error of CFX10
kirbycfd
Hello everyone!
When I finished the calculation, the error display as follows:
An error has occurred in cfx5solve: The CFX-5 solver has terminated without writing a results file. Command on host kirbycfd exited with return code 0.
An error has occurred in cfx5solve: Error reported by IO module: iif_open: can't read the first seven characters: Invalid argument
An error has occurred in cfx5solve: Error reported by IO module: iocnt: open the primary file failed An error has occurred in cfx5solve: Error from IO module while opening :\ES\DISCFX\Distributor2_001.dir\136_full.bak: "iocnt: open the primary file failed" IO_READ_ERR(10): Error reading from disk.
An error has occurred in cfx5solve:Error reported by IO module: iif_open: can't read the first seven characters: No such file or directory An error has occurred in cfx5solve:Error reported by IO module: iocnt: open the primary file failed An error has occurred in cfx5solve:Error from IO module while opening D:\ES\DISCFX\Distributor2_001.dir\136_full.bak:"io cnt: open the primary file failed" IO_READ_ERR(10): Error reading from disk.
An error has occurred in cfx5solve: Error creating directory D:\ES\DISCFX\Distributor2_001 for additional output files: Not enough space.
There is 3-G Hard Disk space in my disk.
Thank! Best Regards!
Old   March 7, 2007, 01:11
Default Re: Help! Error of CFX10
kirbycfd
And no result file generated.
Above Error displays when I let the Computor running itself about several hours. if I keep using the PC, there is no such errors.
Thanks!
Old   March 7, 2007, 08:11
Astrid
Errors like these can occur if you have opened the backup file in Post while the solver is trying to move it. It can also happen if you have a huge particle track file. Do you have something like this?
Astrid
Old   March 7, 2007, 19:33
kirbycfd
Thank you Astrid!
I opened the backup frequency in solver, and not in post just the error displayed. And no particle track in the model.
Maybe this is the error of mis-install of software?
But if I running a simple example which converged in about 100 iterations, No error display.
Thank you!
Can CFX10 simulate the subcooled boiling near wall Gu Hanyang CFX 0 October 2, 2008 03:11
Importing CFX10 data into CFX 11 Stephen CFX 1 May 10, 2007 23:42
Importing CFX10 data into CFX 11 Stephen CFX 0 May 9, 2007 06:55
CFX10 Released? BI CHANG CFX 9 August 12, 2005 12:31
how to use transtional models in CFX10? zuozicheng CFX 1 August 1, 2005 18:33
