Transient vs Steady State
Old   April 12, 2007, 10:46
Default Transient vs Steady State
Adam
What are the main differences between running transient and steady state?
I have a fourier series inlet velocity profile at my inlet that changes with time. When I run transient, the profile changes and settles into a different profile (peaks and troughs become smaller).
I have ran it with up to 1000 timesteps for a total time of 0.117s, and on a couple of grids (fairly coarse), but it makes little difference.
When I alter the profile so that the time is manually changed, and run it steady state at different time values on the same coarse grid, the profile is replicated perfectly.
Any ideas as to what is happening with the transient case? Can i run steady state using appropriate time values to manually alter the velocity profile instead of running transient and writing results at thos timesteps? The transient behaviour in the domain is due to the transient inlet velocity profile.
Many thanks
Adam
Old   April 12, 2007, 11:34
Default Re: Transient vs Steady State
Juan Martin Catelén
I don't know how is changing your inlet velocity profile, but in transient, the profile may be doesn't have time to settle as in steady state because the inlet profile is changing at the same time. So, by running it in steady state your are not seeing the dynamics of the system. The results should be equal if the time for reaching the steady state is significantly smaller than the time that takes to the inlet profile to change. Bye.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Steady State Vs Transient answers Kushagra CFX 25 July 23, 2017 03:20
Steady state vs. mean transient analysis of flow behind a circular cylinder Heini Main CFD Forum 1 June 9, 2011 06:47
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Mass Diffusion: Transient and Steady State BC rval CFX 3 November 19, 2008 00:52
