Opening CFX10-Mesh with CFX11
Old   May 9, 2007, 07:11
Default Opening CFX10-Mesh with CFX11
Luis
I have problems opening with CFX11 a mesh definition file (.cmdb) which was created with CFX-10. I am using three files which were created with CFX10: .agdb, .cmdb, .cmdat
I open without any problem the geometry file (.agdb). Then I select "New Mesh", and in the Meshing window I open the file (.cmdb). At that moment CFX generates a new project, and opens the mesh definition file but cannot read it properly. It does not recognize some 2d composite regions.
Has anybody gone through this problem?
Thanks for your help
Luis
Old   May 10, 2007, 23:37
Default Re: Opening CFX10-Mesh with CFX11
Johnny
A .cmdb file from CFX-Mesh 10 does not contain the mesh, only the mesh settings. You need to write out a .gtm file from CFX-Mesh 10. In CFX-Mesh 11 the .cmdb does contain the mesh.
Old   May 11, 2007, 11:56
Luis
That is what I have done. I have used the .gtm file in CFX-11 directly. But I think it should be possible to open a .cmdb file (mesh settings) with CFX-11 and then generate the .gtm file (mesh) with CFX-Mesh 11. Otherwise you still have to continue using CFX-10 in order to change the mesh settings, then generate the new mesh, and then open the .gtm file with CFX-11. Which means that you need to keep both versions installed.
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Importing CFX10 data into CFX 11 Stephen CFX 0 May 9, 2007 06:55
Opening a mesh file in gambit Vidya Raja FLUENT 17 September 30, 2006 02:43
