Importing CFX10 data into CFX 11
Old   May 9, 2007, 07:00
Default Importing CFX10 data into CFX 11
Stephen
Hello all,
I have had problems with importing CFX10 data of a transient simulation into CFX11. I have success with steady state simulations.
Below is a list of all the methods I have used with no avail.
Sim. Type TRANSIENT System LINUX
Method CFX10 .def OVERWRITE IN CFX11 Run Mode CFX11 - MPICH DISTRIBUTED PARALLEL/PVM DIST. PARALLEL Result CODE 1ERROR
Method IMPORT CFX10 .def FILE INTO CFX11 SOLVER Run Mode CFX11 - MPICH DISTRIBUTED PARALLEL / PVM DIST. PARALLEL Result CODE 1ERROR
Method IMPORT CFX10 .cfx FILE INTO CFX11 - FAIL TO IMPORT
Method IMPORT CFX10 .gtm FILE INTO CFX11 - CREATE BC IN CFX11 Run Mode CFX11 - MPICH DISTRIBUTED PARALLEL Result CODE 1ERROR
Method IMPORT ICEM MESH INTO CFX11PRE - CREATE BC IN CFX11 Run Mode CFX11 - PVM DIST. PARALLEL Result CODE 1ERROR
Method IMPORT ICEM MESH INTO CFX11PRE - CREATE BC IN CFX11 Run Mode CFX11 - MPICH DIST. PARALLEL Result PIPE 13 ERROR
Method IMPORT ICEM MESH INTO CFX11PRE - CREATE BC IN CFX11 Run Mode CFX11 - PVM DIST. PARALLEL Result CODE 1 ERROR
I thank you kindly for your help.
Regards,
Steve
Old   May 10, 2007, 23:42
Default Re: Importing CFX10 data into CFX 11
Johnny
Does the transient case run in CFX 10 in parallel? When you import the ICEM mesh into CFX 11 Pre, does this run in serial? Is your version of Linux suported?
Importing or Creating 2D Flat Surfaces into CFX Sam CFX 5 March 30, 2013 11:11
Data Read Error ansys CFX fcabrales CFX 3 April 18, 2011 18:21
Problems with importing ICEM-CFD mesh in CFX signofra CFX 3 March 3, 2010 10:08
Importing Temperature Field from CFX to ANSYS baserinia ANSYS 2 March 1, 2010 10:52
importing vertex data Mattis Voss FLUENT 2 November 4, 2005 01:12
