conjugate heat transfer
Old   May 21, 2007, 21:57
Default conjugate heat transfer
haiwind lee
i use ansys 9.0 to simulate conjugate heat transfer problem include fluid and non-fluid domain. but the non-fluid domain has no temperature field. element:141 fluid material number:1 non-fluid material number:>1 flow and temperature equations are solved at the same time. transient analysis is true Do i need set something else?
Old   May 22, 2007, 05:00
Default Re: conjugate heat transfer
Joe
There is a tutorial that covers CHT.
Old   May 22, 2007, 09:19
haiwind lee
Thank you for your reply! i do it as ansys help told me, but the result seems wrong. the solid domain has no temperature field, which is still the surrounding temperature, no change. do you have any more tutorials or do like this? Give me some suggestions. thank you.
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 17:31
Conjugate heat transfer and radiation modeling questions shankara.2 FLUENT 0 April 21, 2009 15:55
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
