batch run
Old   June 17, 2007, 13:06
Default batch run
N.R.
when I try to set up a batch run (using windows for test purposes) My batch script will stop after the line:
icemcfd -batch -script source\icem_volmesh.rpl
(where icem_volmesh.rpl is a replay file I recorded earlier)
When I try to use: start /wait icemcfd -batch -script source\icem_volmesh.rpl
the new command window that opens will not close.
I tried to put ic_quit as the last command into the .rpl file but it makes no difference.
Any ideas?
Thanks in advance,
N.R.
Old   June 17, 2007, 22:44
Default Re: batch run
Jack
Hi! Sorry Instead of answering your question, I need your help to get started with batch mode run. I am quite new to CFX so please tell me how to start a batch run. Thanks
Jack
use batch mode to run an unsteady case PaulineP FLUENT 9 April 4, 2019 08:18
how to create input file to run fluent in batch Aireen FLUENT 6 November 21, 2016 08:27
problem with running UDF in batch mode James FLUENT 0 June 6, 2006 06:49
Cycling a transient run Chetan Mistry Phoenics 0 March 3, 2004 09:50
Batch Run Ogbeni CFX 4 October 15, 2003 12:33
