Semipermeable wall
Old   June 22, 2007, 03:49
Default Semipermeable wall
Terje
Hi!
I am running multiphase simulations and I believe it shoud be possible to model a wall which is permeable to only one fluid. That is, for one fluid it behaves as a wall and for the other as an outlet or opening. Does anyone know how to do this in CFX. I have seen that you can make the wall fluxes dependent on volume fraction, but I do not quite see how to make the wall semipermeable from that.
Thanks for any help!
- Terje
Old   June 23, 2007, 05:28
Default Re: Semipermeable wall
Johnson
It depends what you want to do:
If you want to model a membrane which allows a dispersed gas phase to escape, you can use the 'degassing' wall boundary option. This treats the boundary as an outlet for a dispersed phase and a no slip wall for a continuous phase.
Johnson
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
