Opening pressure and direction
Old   July 28, 2007, 15:43
Default Opening pressure and direction
Gui
I'm studying the flow in the upper plenum of a pressurized water reactor. I need to specify inlet boundary conditions at windows that are located on each face of square tubes. I first specified a Total Pressure inlet boundary condition. But during the calculation, a message in the solver says that a wall has been placed at these inlets in order to prevent fluid from flowing out of the domain.
That's why I now specified an Opening pressure and direction boundary condition. I want to know if that condition is realistic for my situation and what happens if the fluid flows out of that inlet (is that flow lost like with an outlet condition or does it still flow in the domain).
Thank you
Old   July 28, 2007, 16:03
Default Re: Opening pressure and direction
Gui
I realised my question is maybe not comprehensible.
So I need to specify an inlet condition at each window of a square tube. There are two windows on each face of the tube (8 in total). So I want to know if I specified an opening pressure with directions of the flow out of the tube, what happens to the flow that enter the boundary on the opposite direction (the flow that enters in the tube) : does it that flow, after entering the tube, leaves it through another window or does CFX consider it as an outlet?
Old   July 30, 2007, 09:09
Robin
Have you read the documentation on openings?
Help setting up pressure function across opening Jenny CFX 3 October 18, 2007 00:16
Pressure drop of valve with valve opening of 30% elogesh Main CFD Forum 2 January 5, 2007 12:30
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
