July 3, 2007, 07:22 |
Do not use free slip walls !!!
I found from the help files that "For planar 2D geometries, do not use free slip walls; doing so will hurt accuracy because control volume gradients will not be computed." I do not understand exactly why it reduce accuracy, could anyone please explain this to me in deep detail? Thanks.
Atit |
July 3, 2007, 08:24 |
Re: Do not use free slip walls !!!
If you have a 2D geometry which is one element thick, make sure you use symmetry conditions rather than free slip walls on the transverse planes. If you use slip walls, you will have only first order accuracy; for example, the advection scheme will be first order upwind because the gradients used for second order corrections are zero.
FREE SLIP BOUNDARY WALLS.......HOW? | shehab abdelrahman | FLUENT | 0 | February 12, 2008 00:25 |
Free slip and no slip. | Yung | Fidelity CFD | 2 | August 16, 2006 09:24 |
Free slip and no slip. | Yung | Phoenics | 3 | March 2, 2006 11:04 |
Free slip and no slip. | Yung | Siemens | 0 | February 4, 2006 10:37 |
Free slip and no slip. | yung | FLUENT | 0 | February 4, 2006 10:26 |
