Convergenze problem in radial diffuser!
Old   July 20, 2007, 05:11
Default Convergenze problem in radial diffuser!
Nicola
Hello everybody!
I want to simulate a rotating radial diffuser! I use periodic surface to simulate only 1/13 of all! B.C. are: rotating fluid domain, liquid water inlet mass flow and velocity direction defined in Cylindrical Components opening on outlet domain with Static Pressure for Entrainment (zero gradient) hub and shroud are walls no slip (k-epsilon turbulence model) Periodic surface with rotational periodic. After 110 iterations I have an overflow! How can I resolve the problem? I decreased timescale but without succes! Thank you
conduction problem venkataramana OpenFOAM 3 December 1, 2013 07:30
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
Radial fan problem : Attn Razvan and all Farhath FLUENT 0 September 26, 2007 04:18
radial inflow turbine rotor periodicity problem Nanda FLUENT 1 July 17, 2006 14:52
radial inflow turbine rotor periodicity problem Nanda FLUENT 0 July 11, 2006 20:35
