simulate contraction part of wind tunnel
Old   July 30, 2007, 01:55
Default simulate contraction part of wind tunnel
fadly
Hi...I'm trying to simulate one part of the wind tunnel body(vacant body w/out screen and honeycomb)..from the settling chamber > contraction > test section...What should I put in the solver (convergence control and equation class setting).In fact..I want to get 80 m/s in the test section.what kind of turbulence model and requirement should be taken....Thanx
Old   July 30, 2007, 19:28
Default Re: simulate contraction part of wind tunnel
Turbulence model - SST should be good here. If you are interested in the development and/or transition of the boundary layer on the tunnel walls then consider the transition model.
Should be a straight forward simulation.
Old   July 31, 2007, 02:17
fadly
Thanx Glenn...I'll try it after this.But for your information..the wind tunnel is for "LOw Speed Wind Tunnel"...is it ok??before this i'm just using K-Epsilon, Thermal Energy...the result is convergence but not so ok graph at the beginning.how can i improve this...you got any ideas??
Wind tunnel boundary conditions Stef06 FLUENT 2 December 8, 2010 12:25
flow in cyclic wind tunnel yogesh@cfd Main CFD Forum 0 November 8, 2010 04:28
defining velocity profile in a wind tunnel model Erdem FLUENT 0 June 20, 2006 13:00
Wind Tunnel Website now online Mike Worthey Main CFD Forum 0 June 6, 2000 02:27
wind tunnel correction Arthur Chen Main CFD Forum 2 September 4, 1998 18:42
