problem pure diffusion
Old   July 31, 2007, 11:44
Default problem pure diffusion
Jorn
Hi, I have a cylindrical domain (1 mm diameter, 5mm length) with opening boundaries defined at the two opposing faces. The value for an additional variable is 1 kg/m3 inside the channel and 0 kg/m3 at the opening boundaries. I have defined water 25C as my fluid inside the channel and switched on kinematic diffusivity for the additional variable with value of 0.5e-5 cm2/sec. There is no convection. I do a transient run with total simulation time 30 sec. At t = 30s, I see not even a slight change in concentration at the edges, i.e. no diffusion out of the domain seems to take place. Anyone a suggestion what I do wrong here?
Thanks, Jorn
Old   July 31, 2007, 11:53
Default Re: problem pure diffusion
opaque
Dear Jorn,
What type of Additional Variable are you using Poisson, Diffusive, or Transport Equation?
By default, CFX does include diffusion at inlets/opening/outlets for the Transport Equation option..
Hope this helps,
Opaque
Old   July 31, 2007, 11:56
Jorn
I'm using the transport equation option... Jorn
Old   July 31, 2007, 12:06
Jorn
Ok I see now what went wrong... in the 30 sec. the effect of diffusion is small and the mesh at the opening boundaries was too coarse to resolve this.
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
FVM for diffusion problem or dispersive problems? Wen Main CFD Forum 0 February 22, 2006 13:34
Diffusion problem ravi varma FLUENT 6 December 8, 2002 23:10
