total enthalpy variation in nonequilibrium steam
Old   August 22, 2007, 09:08
Default total enthalpy variation in nonequilibrium steam
Tim
Hi, I have to compute a steam flow through a nozzle using the nonequilibrium steam model (condensation occurs in the nozzle). The walls are adiabatic but the total enthalpy of the fluid varies on its way through the nozzle (h_tot,out is much higher than h_tot,in).
Is anyone familiar with this problem? Is there a physical explanation or does a numerical proplem occur?
p.s.: I'm sure that my mesh is accurate as I tested it with equilibrium steam.
Old   August 22, 2007, 14:54
Default Re: total enthalpy variation in nonequilibrium ste
jakjak
How much higher are we talking about here? Have you try running it in double precision? Also, I was just wondering what's the mass flux for each phase?
Old   August 23, 2007, 05:54
Peter
@ jakjak: thanks for your response
yes, I tried running double precision.
Total entahlpy remains constant in the convergent part of the nozzle. From the throat (nucleation zone) to the outlet (supersonic) total enthalpy increases (1,2%).
I used the method massFlowAve() to average h_tot at the inlet and the outlet.
Liquid mass fraction is zero at the inlet. The mass flow at the inlet is equal to the mass flow at the outlet (or did you mean interphase mass flux?).
Old   August 24, 2007, 09:07
jakjak
What you have described for the boundary conditions seem reasonable. As I understand, the total enthalpy includes static enthalpy and kinetic energy from the flow. Could the raises in total enthalpy be caused by flow acceleration?
What about the imbalance from the inlet to outlet ?
rhoSimpleFoam loss in total enthalpy Chrisi1984 OpenFOAM 14 May 6, 2013 03:17
Problem with total enthalpy HaitAV OpenFOAM Running, Solving & CFD 0 September 17, 2010 04:44
Would you help explain the drop of total enthalpy? samxsl FLUENT 2 May 6, 2009 20:45
Total Enthalpy tangd OpenFOAM Running, Solving & CFD 0 August 25, 2006 08:28
meaning static enthalpy and total enthalpy mspark Siemens 1 April 1, 2004 06:20
