Urgent help: RMS problem!!!
Old   September 4, 2007, 18:40
Default Urgent help: RMS problem!!!
Anh
Hi all,
I am modeling heat transfer between solid and liquid with phase change. The geometry is quite simple. They are two cubic and i meshed it by CFX. When i run it in transisent, even though i set the time step very small (2e-10 second, total time for my simulation=1e-6 second), RMS is strongly fluctuation. RMS is below 1e-4 but it's up and down which create a row of color. Domain imbalance is very good (below 0.1%).
So, if the RMS is fluctuation but domain imbalance is good, the result is applicaple? Anybody know how to fix it??? Pls. advise me.
Thank in advance.
Old   September 6, 2007, 10:46
Default Re: Urgent help: RMS problem!!!
Omer
Well, for most of the transient analysis, it is only normal that the RMS would fluctuate for each substep in the iteration!
How good is your solution can only be verified by comparing it with a real case.
And you need to be really sure if 1e-4 does really give you a convergent result. If you have a monitor point of some kind when you run the steady state solution, you would get to know when a good amount of convergence is reached.
Old   September 7, 2007, 22:44
TB
What RMS are you using? It could be due to the way you set up the problem too.
Old   September 8, 2007, 02:28
Anh
Thank you Omer and TB.
I set RMS=1e-4. My model is quite sensitive with mesh and tiem step. I tried to reduce mesh size and time step but it still oscillation.
Anybody know how to mesh by hex element? My current mesh is tet and prism then i think it's not good enough.
Thanks in advanced
Old   September 8, 2007, 13:47
Omer
If you are using CFX Mesh , you wouldn't get a Hex mesh.
Depends on what kinda meshing tool you would be putting to use.
Urgent problem - orthotropic material in ICEM Luk CFX 6 August 30, 2006 08:06
Urgent plotting problem in Post...Please help. Alan CFX 1 March 28, 2005 18:46
Multiphase Problem (Urgent) Dadang CFX 4 June 21, 2004 07:46
Urgent help on Sand casting problem arunprasad FLUENT 0 April 18, 2004 05:04
An urgent problem, HELP!!! Fanadam FLUENT 1 May 2, 2003 23:38
