Dependency of turbulence model on mesh size
Old   September 20, 2007, 00:14
Default Dependency of turbulence model on mesh size
Kushagra Mittal
The flow I am trying to simulate is highly swirl in nature. I started with a very coarse mesh without resolving the near wall mesh. I used 4 mm tetra element with T-Grid scheme while the diameter of circular section is 76 mm.
What I find, velocity profiles and other results are exactly same for laminar and turbulent models; respectively. The reynolds number would be around 3*10^5 to 5*10^5.
I can be assumed a beginner in CFD world. Could you please through some light on importance of mesh size and near wall resolution on turbulence models. I have studied about y+ and wall function but I am wondering if turbulent models might not affect simulations AT ALL even with a coarse mesh and high y+. Should not I see some difference in my solutions.
Thanks in advance, KM.
Old   September 20, 2007, 18:51
Default Re: Dependency of turbulence model on mesh size
Wall functions will not be the problem with your simulation.
If your flow has high swirl then forget about all the two equation turbulence models. This means k-epsilon, k-omega are no good as none of them can handle swirling flows. The only exception is the SST model has a curvature correction option as a beta feature. This may mean the SST model is OK, but I have never used this option so no guarantees.
For swirling flows you really need to use a Reynolds Stress based model or DES/LES. Of course you need to use wall functions with these models but at least they can handle the basic physics of the flow.
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
[ICEM] Help with fixing imported IGES model siw ANSYS Meshing & Geometry 24 August 24, 2010 11:22
Mesh size and solver residuals... Scott CFX 5 December 15, 2008 17:10
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
