September 24, 2007, 08:48 |
INFO: Rotating volume
1) when set up a rotating volume, only the impeller passage must be define rotating in CFX?
2) If I select all the meshes, the inertial terms will be add to all my fluid, and this isn't right? I say that because I have noticed an total temperature rise outside the impeller! thx for replies Dothan |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 03:14 |
Control Volume , Finite Volume, Finite Control Volume, Finite Element Method | technocrat.prakash | Main CFD Forum | 1 | April 24, 2010 19:24 |
FloWorks (Flow Express) Volume Goal Setting Issue | rbigelow | FloEFD, FloWorks & FloTHERM | 1 | November 16, 2009 01:32 |
OpenFOAM with Cygwin | kitchener | OpenFOAM Installation | 6 | April 24, 2006 23:09 |
