CFX Monitouring on the region in domain??
Old   September 27, 2007, 10:29
Default CFX Monitouring on the region in domain??
july
My problem seems rather common,I have a region in the domain,it is something like interior face.(not a boundary nor an interfaee) But I want to make the integration of one variable (etc,pressure) on the region as one as one additional expression.
CFX11.0 can easily tackle the problem since its expression syntex allows like this" Avearea@REGION:user_region" while user_region is the name of the region I defined in advance.
But since our lab hasn't buy CFX11.0 ,so I have to use CFX10.0, while CFX10.0 doesn't support the syntex like "Avearea@REGION:" .In CFX10.0, what can be placed after @ is limited to boundary or interface. But my region is neither a boundary or an interface.
so I am wondering if there is any other approach to get the same result.
Thanks in advance
Old   September 27, 2007, 16:04
Default Re: CFX Monitouring on the region in domain??
CycLone
The only way to do this with 10.0 is to apply an interface at your region then write a call back to the interface region.
Old   September 28, 2007, 04:17
july
Dear Cyclone:
I have apply an interface at that mesh-surface
as you has suggested, but unfortunetly, CfX10.0
still dosen't recognize the interface name I have
difined which is strange with respect to the
documentation in CFX10.0 .If I replace the
interface name with a normal boundary name. Then
it does works , and no syntex error was reported.
What can I do then?
Many thanks.
July
Old   September 28, 2007, 10:46
CycLone
You may need to force the interface to use a GGI connection. There is a parameter to toggle this at the bottom of the interface object definition panel. If you leave it as Automatic, the solver will recognize this as a 1:1 connection and simply merge the grid, thereby removing your region. Forcing it to be a GGI connection should preserve your region. There should be no effect on the solution, although the GGI will add a little extra overhead.
-CycLone
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
different CFX Pre and Post mesh region mactech001 CFX 9 April 11, 2010 21:08
CFX Fluid Domain Movement greg CFX 1 March 25, 2007 08:08
Cancel a domain in CFX solver Neser25 CFX 2 February 19, 2007 11:19
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
