Help for Cp value
Old   September 28, 2007, 03:22
Default Help for Cp value
Gaurang
Dear all,
I Dont know how to get Cp in post processing. I got only total pressure. If I have to insert formula Cp = (P - P0)/(1/2*row*U2), how can I do it.
Please help. Thanks in advance.
Old   September 28, 2007, 03:52
Default Re: Help for Cp value
mac
If you min Cp : specific heat capacity, normally you should get it in the post. If not for your expression, you should firstly define your P0 and after: Cp=(pressure-P0)/(0.5*Density*Velocity^2)
Hope it's help
Old   October 1, 2007, 03:46
Siva
Dear Gaurang, why cant you try out the Cp plot option in the macro calculator function. first you create a polyline around the body where you need to get the Cp values then get the Cp at that region through Macro calculator. i hope it will help.
Regards Siva.K
