October 11, 2007, 08:01 |
Getting solution fields between iterations
Hello everybody!
I try modeling arc with CFX... First of all, I want to do 1 zone model: |Axial Symmetry |Openning |____ | 1) At first iteration I get | _1_| <---- GAS temperature field | _2_| | 2) Calculating Joule-Heating ????? |Arc | | <- walls I need temperature sourface (1,2..N) | | | integrating | _N_| | 3) Change energy source S1,S2,...,SN |____| | 4) Another iteration | | | | Openning I have big problems with step 2 I should get from solution temperature field (how?) Integrate by 1,2,3 sourface for calculating S1, S2,...,SN (joule heating sources) (Can i realize it in User Fortran ? ) |
October 11, 2007, 08:03 |
Re: Getting solution fields between iterations
ASCII picture failed ((
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Low Mach number Compressible jet flow using LES | ankgupta8um | OpenFOAM Running, Solving & CFD | 7 | January 15, 2011 13:38 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 05:55 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
