Writing an expression for fully developed flow!
Old   December 4, 2007, 09:09
Default Writing an expression for fully developed flow!
Usman
Hi guys, i am simulating a flow on a backward facing step. I want to impose fully developed flow at the inlet in a rectangular duct. In CFX tutorials (i think its tutorial 9) where it tells us how to write an expression for a circular pipe. But can i use that expression for a rectangular duct??
I think i cant use it! How can i then write an expression for a fully developed flow at the inlet of rectangular duct.
Old   December 4, 2007, 09:25
Default Re: Writing an expression for fully developed flow
CycLone
Hi Usman,
Instead of using an expression, specify the inlet static pressure and pick the zero gradient option for velocity and turbulence, this will result in a fully developed velocity profile (on any cross section). Note that you will need to specify the flow rate at the outlet.
For the zero gradient option to work properly you must have a grid which is orthogonal to the inlet. If you have a hex mesh, you'll be OK. If it is unstructured, you'll need to add inflation at the inlet.
-CycLone
Old   December 4, 2007, 12:11
Usman
Hi CycLone
Thank you for your answer. Can you enlighten me on how to calculate mass flow rate at the outlet of duct when the simulation is unsteady. For unsteady simulation mass entering the domain is not same as mass leaving the domain.
Usman
Old   December 4, 2007, 14:11
jakjak
Usman,
Is there any reason why your mass flow is not same when it's entering and leaving the domain under an unsteady situation?
Old   December 4, 2007, 15:31
CycLone
Hi Jakjak,
If the flow is incompressible, or the density varies with temperature, it's possible to accumulate mass within the domain in a transient simulation.
Usman,
If that is the case you won't be able to use the approach I described, but how would you have fully developed flow at the inlet if it is changing in time?
-CycLone
Old   December 5, 2007, 06:38
Usman
Yes, exactly for unsteady flow mass accumulates within a domain. I guess the only option i am left with is either to make my duct longer OR i can look into CEL function. Anyways thanks for help guys!
Usman
Old   December 5, 2007, 10:16
CycLone
For the CEL expression, just make the velocity a function of the distance from the wall using the appropriate algebraic relationship for the profile. If you locate a local coordinate system at the boundary, you can use this for the boundary condition and specify the functions relative to this coordinate system.
Alternatively, you could still use the static pressure option, but make the static pressure a function of the local mass flow rate. If you have specific flow rate which is desired, you can set the pressure to increase or decrease as it deviates from this mass flow, but you'll have to be careful about how you do this. Just keep in mind that when you integrate quantities at a boundary, such as calculating the total mass flow or the average pressure, the expression will return the values from the old timestep. In other words, these values are not active.
Here's an example of how to make the inlet pressure respond to the mass flow rate so as to match a desired flow rate. In a steady state simulation this would settle down to a specific flow rate, but it may not get your flow rate exactly in the transient simulation.
Ps old = areaAve(p)@inlet
Mdot spec = 1 [kg/s]
Mdot old = massFlow()@inlet
Ps spec = Ps old + A*(Mdot old - Mdot new)
A = 5 [Pa/(kg/s)]
In the above expressions, Ps spec is the specified boundary value (i.e. put this expression in the boundary condition), and Mdot spec is the desired mass flow rate. A is a linearization coefficient which determines how the pressure will respond.
I put a value here for A, but you'll need to determine one that gives you the right behavior. Ideally, this should be a function of the timestep and represents the dynamic response of the upstream system to a change in mass flow rate. You could derive an approximate algebraic relationship for A by integrating the Navier-Stokes equations over the upstream system. See equations 4, 5, & 6 from the Discretization and Solution Theory or refer to any fluids textbook. By doing so, you are effectively adding a control volume upstream of the boundary.
-CycLone
Old   December 5, 2007, 11:19
Usman
Thank you so much for your help Cyclone. Stay in touch!
Usman
Old   December 5, 2007, 13:38
Greg
instead of using a cel expression, you could also use a BC profile of a fully developed flow on your inlet boundary.
Just model a straight duct with the cross-section of your inlet, and export the velocity profile of the outlet with CFX-Post in a file and import this file as an inlet profile for your backward facing step problem. The length of your duct should be larger than 0.06*Reynolds_Number*Hydraulic_Diameter.
Regards,
Greg
Old   December 5, 2007, 13:46
CycLone
If you take this approach, just extrude a cross section of the inlet and make a mesh with one element in the extruded dimension. Set the model up as linear peridic (in the extruded direction) and specify either a pressure drop or target mass flow on the interface. You'll end up with a fully developed profile which you can use as Greg describes.
-CycLone
Old   December 6, 2007, 08:19
  #11
Usman
Thank you Greg and Cyclone, i will look into this option as well. My static pressure option seems to be working for now!
Old   December 18, 2007, 10:39
  #12
romance
CycLone:
hi, i have a quesetion about your cel function, how to get Mdot new ? would you tell me the CEL expression? thanks!
Old   December 20, 2007, 11:26
  #13
CycLone
Sorry, that should have been "Mdot spec", since the "new" mass flow is desired to be your specified mass flow.
Ps old = areaAve(p)@inlet Mdot spec = 1 [kg/s] Mdot old = massFlow()@inlet Ps spec = Ps old + A*(Mdot old - Mdot spec) A = 5 [Pa/(kg/s)
-CycLone
Nusselt numbers for fully developed laminar flow Danro Siemens 8 July 19, 2012 07:22
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
BC for fully developed turbulent flow in a pipe mmd014 FLUENT 2 May 22, 2009 06:50
Fully developed flow profile icfd Main CFD Forum 3 May 20, 2009 22:21
LES fully developed channel flow Gem FLUENT 4 May 12, 2005 05:30
