ICEM CFD
Old   December 25, 2007, 18:25
Default ICEM CFD
ond
I jast want to know that what is the power of the ICEM that makes it better to generate meshes thanks.
Old   December 27, 2007, 06:21
Default Re: ICEM CFD
pankaj
Hi MR OND!
Have u ever tried ICEM?
Its all from points,curves,surfaces,their transformations, your own mesh stats with no limits(upto certain extent)for all unstr/structured mesh.
Got it.
Old   December 27, 2007, 18:40
Julian Maldonado
Hello! I made several mesh with ICEM CFD 10 and 11 tetra and hexa. If you have a complex geometry I recommend you a tetra mesh, however if you can make hexa mesh, you will have more control of the boundary layer and Y+. I had better results with CFX with hexa mesh.
I've tested Harpoon (Cartesian mesh generator), this mesher is quick but is not so good as ICM CFD.
Best regard,
J.
Old   December 28, 2007, 00:32
rohit
Icem CFD is a very powerful tool for generating Hexa meshing, once you have a mesh you can just play around with the any kind of geometry modification... its saves lot of your time for repeatitive kind of work..
Hexa meshng with icem.i suppose you can get the best quality mesh compared with any other software
Old   January 2, 2008, 06:19
Pratap Kumar DVS
Yes i will agree with all of you.... Icem CFD is good tool for Very good mesh... We can play around once we generate the block file, for even many modifications in the geometry. Its a complete parametric tool for hexa meshing... But needs more patience while projection....
Thanks & reagrds Pratap Kumar DVS
[ICEM] Icem CFD on Linux mechanicaldesign ANSYS Meshing & Geometry 7 March 11, 2021 19:44
Need help icem cfd kakhtar ANSYS Meshing & Geometry 25 January 31, 2017 01:09
Transport mesh from ICEM CFD, to Fluent, to Sysnoise Wieland FLUENT 2 April 15, 2012 06:28
Importing Solidworks part into ICEM CFD MetalSupremacist FLUENT 0 October 8, 2010 17:46
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
