guide me to solve boiling water using heater
Old   January 16, 2008, 09:51
Default guide me to solve boiling water using heater
rizal
i want to ask about a boiling water in kettle using a heater. now i study about the coil shape can it effect the boiling. so i choose using the cfx to do the analyst the boiling time and heat transfer for the heater. so i want to know how to setting the cfx software from meshing until the simulation. i hope, u will give me some guide and advice to finish my work. so reply my email as soon as possible.
Old   January 17, 2008, 04:51
Default Re: guide me to solve boiling water using heater
antonello
There is a similar problem well described in ANSYS CFX 11 documentation. "CFX Help -> ANSYS CFX Tutorials -> Tutorial 14-Conjugate Heat Transfer in a Heating Coil". I think you also have to activate the Buoyancy options to model the convective effect.
Old   January 17, 2008, 04:56
antonello
"lost-contact.mit.edu/afs/net/project/afs32/mech.kth.se/home/mech/daniels/sdfsd.pdf"
This URL links you to an old CFX 5 Tutorials Version.
Old   January 17, 2008, 06:54
rizal
can u give me the way. i lost direction after cfx solver.
Old   January 17, 2008, 11:19
antonello
what does 'i lost direction after solver' mean? Did you obtain a converging solution but you cannot postprocess it?
Old   January 17, 2008, 12:32
rizal
after do the cfx solver, i cannot do the animation. thre are some error. so what can i do to solve this problem.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
guide me to solve extended surface heat transfer Fairid CFX 2 January 17, 2008 13:15
Boiling heat transfer calculation david CFX 0 June 21, 2005 04:17
How to solve another continuum and momentum eqn? west_wing FLUENT 0 August 25, 2003 10:00
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
